Hi, I'm looking for a little input into a new mITX build. This is what I have so far:
YOUR BASKET
1 x MSI Z97I Gaming AC - Devil's Canyon i5 4690K CPU & Mini ITX Motherboard Bundle **£18 Saving** £259.98
1 x Crucial MX100 512GB SATA 2.5” 7mm SSD + 9.5mm Adapter CT512MX100SSD1) £159.98
1 x Kingston HyperX 16GB (2x8GB) PC3-19200C11 2400MHz Dual Channel Kit - Black/Red (HX24C11BRK2/16-OC) £125.99
1 x BitFenix Prodigy Flo Bundle - Black £84.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £60.98
Total : £701.48 (includes shipping : £8.00).
I'll be adding my 7950 to this from my current setup. I also have a Corsair HX520w to reuse.
16GB RAM is probably a bit overkill, I suppose, but I would be doing some video editing and some Illustrator work where I've noticed my current system (4GB) really struggling with bigger files so thought this might help. Tell me if I'm being silly though!
My budget was around £800 but since I'm reusing my 7950 I want to limit it to £700 to save a little. I'll replace the gpu later in the year/early next year. Doing this means I can spend a bit more on other parts like the SSD.
Not planning to overclock initially, so just use the stock cooler for the time being?
How does it look? Any input appreciated.
Cheers.
YOUR BASKET
Cheers.
