Hi all,
After my initial post, I decided to leave it as I couldn't afford it unfortunately. However, I'm currently planning a build in case the next gen consoles fail to impress me enough to pick one of them up. Here's a summary of what I want to acheive.
The build must be:
- Small. I have a Denon DM-38 stereo which will sit either under or on top of the build and I'm aiming for a similar width. Dimensions to come.
- Good quality. I'd rather trade a little power to get a good quality build. Currently only looking at Lian Li and Silverstone cases and I don't want it to feel like a DIY job as it would be kicking around for quite a while.
- Quiet. While silent isn't likely, low noise is preferable as it will sit on top of my desk and may be used as a server or HTPC in the future.
- Powerful enough to play current games at good settings at 1080p and hopefully future games smoothly for a couple of years. It will also be used for video encoding, photoshop and general browsing.
Budget at the moment is around £800 and this will likely come down if gaming becomes less of a priority. This is without OS, monitor and peripherals as I've already got these. I also have access to 8gb of 2133Mhz DDR3 for £35 off of a friend.
I'm currently waiting on Kaveri and the new consoles so this is a very pre-emptive spec and the situation is likely to change as time goes by. That and I may choose to spend the money on life changing trips over gaming
Phil
The build must be:
Phil
