MITX Build SG05 Help needed
Permabanned
31 Jul 2008
Manchester
Right guys im going for a SG05 case, now at the moment i have got :
Q9550 E0
4Gb OCZ Reaper DDR2
Asus P5Q-EM
8800GTS
1Tb F3
500W PSU
Now the decision is... Do i get the Zotac 9300itx board and keep it 775 ?
Or do i get the Zotac H55 itx board and sell my bits now ? I was thinking of a i5 750.... It will be getting a HD5850 when i can find one cheap enough and want the best i can get for gaming.
Which would be better and why ?
It is a dual slot cooler mate. I know they fit as a few on here use them.
I've got one in mine on the stock 300W PSU and it works perfectly so far, no crashes and I've been running GTA4, Modern Warfare 2, Fallout 3 and Dirt 2 on max settings for all those but GTA4 which requires a bit of tweaking due to my dual core, but still runs at high settings and looks a hell of a lot prettier than the console versions. :)
http://forums.overclockers.co.uk/showthread.php?t=18141335&page=2
As you got CPU and RAM i'd say the 9300 :)
Im going for the H55 as its a fresh build but were also considering getting a 9300, But lets not get into that as im a pain on deciding on what to get lol
or you could hunt around and get the zotac g41-itx wifi :)
i just got one for a project i'm about to do :)
they do a g43 version as well both with big savings over the 9300 and as your not using the onbaord gfx thats the only advantage the 9300 has over them pretty much gone.
but the 9300 is a pretty good board to as i have one of them also :)
I'd personally try and get an Intel chipset board as I can't get along with nVidia's chipset drivers at the best of times, but from what i've read the 9300-ITX seems a decent board.
right guys, got myself a i7 860 and would like yo overclock it, now after reading up the zotax is useless, so i was looking at the DFI mitx board or going matx like the EVGA p55 micro... What you guys think ?
Also what decent cases are there for matx ?
Cheers
The only place I can see the Zotac g41-itx wifi being sold at in the UK looks a bit dodgy. Is it the Euro place BTW??
