12 May 2013 at 16:55 #1 BobbyUK BobbyUK Associate Joined 21 Feb 2012 Posts 92 ITX Build Case - Lian Li PC-Q25B Mini-ITX Cube Anyone recommend a decent spec, learning forward to i3 build. HD - 5 X WD RED 3TB Thx
12 May 2013 at 22:12 #2 ozzymundo ozzymundo Associate Joined 30 May 2012 Posts 231 Budget? What's it going to be used for? Do you need OS, peripherals etc?
12 May 2013 at 23:12 #3 BobbyUK BobbyUK Associate OP Joined 21 Feb 2012 Posts 92 £400 max - that's not including the hd's NAS/fileserver
