mixing brands
21 Jun 2010
infornt of my PC
I am soon going to replace my 8800 gts 640 with a brand spanking new 6950.
Is it worth keeping the 8800 in the 2nd slot and running it with the 6950?
Can you mix nividia and ati in one system?
Is it worth it?
You can do it with a patch.
Whay games do you play?
If they are ones that utilise physx then it might be worth putting it in. Otherwise just keep it as a spare.
