Mixing Corsair SP and AF RGB fans
27 Nov 2003
Hi all,
Does anyone else here use a mixture of AF and SP corsair fans in their corsair RGB hub? I assumed that they will all work but after plugging these into the same hub, only 3 out of the 5 fans work and one of them is giving me weird colours. Do I need a separate hub?
Which specific version(s) of those fans are they? I mixed the AF RGB Elites and SP RGB Elites and they'll work together if you set the hub to 8-LED Series Fans mode in iCue. That said, I hated the noise and vibration of the AF fans so swapped them for more SPs instead.
