Mixing different ohms
11 Oct 2008
Death Star
Can someone offer correct advice please, I own a Onkyo TX-474 receiver with a surround setup consisting of Mordaunt Short Avant series floor standers, centre and book shelf bi poles with a ohm rating of 4 - 6ohms. my receiver has either 4 or 6ohms as an option with it currently set at the 4ohm option. I am now starting to upgrade my setup and have purchased 8ohm Klipsch floor standers. Is it safe to add and replace my current floor standers (Mordaunt) with the 8ohm Klipsch in the meantime until I save more money and still run the rest of the 4 - 6ohm setup with the receiver still set at 4ohm? or should I wait until I have a full 8ohm setup with new receiver as I plan to? I don't want to damage anything.
It will be fine, they're just twice as hard to drive, so if they're 100w speakers for instance and you drive them with 4ohm you'll need 200w to power them.
Or another way they'll be fine they'll just be a bit quiet compared to your other speakers.
Thanks for that!! When you type my question into a search engine it comes back with such conflicting opinions I was getting a headache.. :confused:
The receivers 4 Ohm setting is akin to putting a wedge under a cars accelerator to prevent it being pushed all the way down. It's not actually changing the receiver to better handle a low Ohms load. It's just limiting how much power it makes available.
Like any limiter, there's a point where you can hear it start to take effect. An example would be a sudden explosion in a movie. Think about the Batman film, The Dark Knight. Joker is leaving the hospital and fiddling with the detonator. You can hear him muttering as he jabs at the stick. Suddenly KA-BOOOOM, or more specifically KA-Boooom. The limiter cuts in and the sound shrinks. The receiver has temporarily throttled the power so that too much current can't be drawn by the speakers. You need to get to a certain volume limit before the peaks will trigger this response, and there are several factors affecting what that point will be such as the room size for the SPL and the sensitivity of the speakers. But once you hear what's going in, that's the point where you can tell what the 4 Ohm limiter is doing.
Although an 8 Ohm impedance, your Klipsch speakers can be a tricky load for amps. The horn tweeter is incredibly efficient and has high sensitivity, but the mid/bass drivers if measured alone would be a very different story. Klipsch quotes 94dB for their R-610F, but that's because the horn-loaded tweeter is pulling up the average.
All speakers have a frequency response that can be measured and graphed from the lowest frequencies to the highest. Here's some interesting reading. Klipsch RP-600M Speaker Review | Audio Science Review (ASR) Forum
None of this should stop you enjoying your system, but it is an example of how the spec sheets don't tell the full story.
