Someone must have tried it?
I have an ML110 G3 here that runs most of my dev stuff. I have no need for ECC ram and have a spare 1GB module (non-ECC) laying around, which would be a useful upgrade.
The current ram appears to be unbuffered items
dmidecode dump;
dmidecode dump;
Code:
Handle 0x0020, DMI type 16, 15 bytes
Physical Memory Array
Use: System Memory
Error Correction Type: Single-bit ECC
Maximum Capacity: 8 GB
Error Information Handle: Not Provided
Number Of Devices: 4
Handle 0x0021, DMI type 19, 15 bytes
Memory Array Mapped Address
Starting Address: 0x00000000000
Ending Address: 0x000000003FF
Range Size: 1 kB
Physical Array Handle: 0x0020
Partition Width: 0
Handle 0x0022, DMI type 17, 27 bytes
Memory Device
Total Width: 72 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM1
Bank Locator: Not Specified
Type: SDRAM
Type Detail: Synchronous
Speed: 533 MHz (1.9 ns)
Manufacturer: 2CFFFFFFFFFFFFFF
Serial Number: 00998802
Asset Tag: Not Specified
Part Number: 9HTF6472AY-53EB3
Handle 0x0023, DMI type 20, 19 bytes
Memory Device Mapped Address
Ending Address: 0x0001FFFFFFF
Range Size: 512 MB
Physical Device Handle: 0x0022
Memory Array Mapped Address Handle: 0x0021
Partition Row Position: 1
Handle 0x0024, DMI type 17, 27 bytes
Memory Device
Total Width: Unknown
Data Width: 64 bits
Size: No Module Installed
Form Factor: Other
Set: None
Locator: DIMM2
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer:
Serial Number:
Part Number:
Handle 0x0025, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x0024
Handle 0x0026, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: DIMM3
Type: SDRAM
Serial Number: 009A8802
Handle 0x0027, DMI type 20, 19 bytes
Starting Address: 0x00020000000
Ending Address: 0x0003FFFFFFF
Range Size: 512 MB
Physical Device Handle: 0x0026
Handle 0x0028, DMI type 17, 27 bytes
Memory Device
Data Width: 64 bits
Form Factor: Other
Set: None
Locator: DIMM4
Type: Unknown
Type Detail: None
Speed: Unknown
Manufacturer:
Serial Number:
Part Number:
Handle 0x0029, DMI type 20, 19 bytes
Range Size: 1 kB
Physical Device Handle: 0x0028
