Mixing Fans
6 Jan 2013
Rollergirl
I have a Noctua 2000rpm industrial fan. It runs fine, but if I use a Y splitter and add a Corsair PWM fan then the Noctua stops. If run 2 Noctua then they are fine, but it seems if I mix Noctua with Corsair then only the Corsair will spin.
Is this normal?
Nope that's really weird. Have you tried raising the PWM duty cycle? Just speculating. I know there are some PWM fans that are programmed to stop at low duty cycles...
Odd I run a mix of SP120 and other fans and not having issues granted I use a Phanteks fan hub not y splitters.
Not only this, but different fans of the same model will have slightly different stalling speeds for starting the fan.
