Mixing Hazro 27 ips with 2xdgm ips screens eyefinity
14 Aug 2011
Hello,
Have a hazro 27 inch ips 2560x1440 and was wondering if anyone is running a hazro with some dgm ips screens in surround vision or eyefinity?
I need to use the dgm monitors because they have display port.
ARe the panels the same?
THanks.
I wouldnt see an issue as long as the Hazro was teh centre screen, and depending on your GFX card with the DP for the known bios issue although you do have 2 others to check the bios on. I am not 100% sure about the panel being teh same as I think the the DGM has the newer panel. Look at the dell over the DGM.
