Mixing Homeplugs
16 Apr 2007
UK
Hey all,
I currently have one of these downstairs (and the other upstairs)...
However, I have a virgin media router downstairs and the rest of my family use it wirelessly. As some of you may know, the wireless connectivity on these routers is pretty bad. It continually cuts out and what not...
So I figured I would change the homeplug downstairs to a wireless one so that the wireless connectivity would be dealt through the homeplugs instead of the router...
So my question is... Does it need to be a TP-Link homeplug downstairs, or can I just pick up any wireless homeplug, plug it in and go?
Thanks,
Marky
TP-Link will have a wireless N homeplug available sometime soon. It'll be available as a kit or on it's own.
Here is the product you are talking about.
http://www.overclockers.co.uk/showproduct.php?prodid=NW-056-TP&groupid=46&catid=1604&subcat=
What This Product Does
TP-LINK’s Wireless N Powerline Extender Starter Kit extends an Internet connection to every room of the house over existing electrical circuitry. All devices in the room have two options to get access to TL-WPA281, whether through wireless or using an Ethernet cable. With 200Mbps Powerline link rate and 300Mbps wireless N rate, it is ideal for bandwidth consuming or interruption sensitive applications like video streaming, online gaming and Internet calls. With TL-WPA281, Internet can be available everywhere in your house.
Up to 200Mbps, 300 Meters
With advanced HomePlug AV technology, TL-WPA281 Starter Kit provides users with stable, high-speed data transfer rates of up to 300Mbps on a line length of up to 300 meters. Together with its built-in Qos and powerful AES encryption, the TL-WPA281 is a great choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
300Mbps Wireless N Rate—Extend Wireless Coverage
With wireless speeds of up to 300Mbps, users can effortlessly extend their network via the existing powerline and broadcast a wireless signal to another area of their home or office.
Multiple HD Streaming
200Mbps powerline and 300Mbps wireless ideal for lag-sensitive applications.
Pair Button for Easy Network Security
Simply by pushing the Pair button on the adapters, users can set up a hassle-free Powerline network within minutes, complete with 128-bit AES encryption for network security and data protection. It's that simple!
1. Plug the adapter into the power outlet
2. Connect the device via the network cable to the adapter
3. Press the encryption buttons—and you're done!
WPS One Button Security
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WPA281 Starter Kit features WPS One Button Security Setup that allows users to almost instantly setup their security simply by pressing the "WPS" button on the adapter automatically establishing a WPA2 secure connection, which is more secure compared with WEP encryptions. Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
Support QoS for Advanced Multiple-media Optimization
Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Game, and Audio or Video, Voice over IP, and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
You can pre order it from overclockers and the ETA is 22/03/12 £73.99 inc VAT
Thanks a lot for the advice - yeah I saw that they are bringing out the wireless one... No single one at Overclockers though - so may have to shop elsewhere :(
Hi Marky,
You can buy single units and the cost would be between £36 -£39.
I cant post links as this would break rules, but if you just Google [single TP LINK Wireless N Powerline Extender] you will find them.
Hi Marky,
Yep got them! :) Thanks a lot bud :)
