Mixing memory advice
11 Oct 2005
Derbyshire
My PC (In sig) runs fine, I just have a stick of generic (cheap ish £40) of 1 x 512MB 3200 ram, would it be of benefit to put that into my present machine ??
Or not ??
thanks
if u're running bf2 i would yes.
bear in mind it may not overclock as well, run as tight timings and will lose dual channel support if u're mobo has it.
but i did it for bf2 and even used 3x512 and 1x256 improved loading etc even with the loss of dual channel.
if its just day to day stuff i wouldnt as u'll lose the benefit of the ocz.
Probably not. For 1) it probably won't work at all unless you raise the timings of your OCZ to equal the timings of the generic ram and even then it might not 2) You'll lose your ability to run the ram dual channal because it will no longer be balanced 3) Raising the timings will slow the OCZ down which will slow down aspects of your current performance 4) If you are overclocking you can kiss your stability at that level good bye.
On the other hand, an Extra half gig capacity will help out with a few games. It's not a total not brainer, but be prepared that it might not work and it may have an aggregate impact on performance that is negative.
