Mixing memory help
1 Jun 2006
Hi there guys,
I recently purchased some Mushkin 2GB DDR HP3200 memory from overclockers, and I also have a set of 2GB OCZ DDR PC3200 (Value series)
I would like to know if i could use these sets of memory together, and will i see any performance difference or a decrease in performance? I did try them all togther for about 5 min to see, but they seem all to run at 2.5-4-4-8 which is the speed of the OCZ value memory.
The Muskin should run at 3-4-4 but it seems they run at the lower speeds of the OCZ memory.
I know your probably gonna say.. Why do i need 4GB of memory, but im only testing to see if i see any gain in performance.
Im new to all this so go easy on me ;)
Thanks
As far as I know at stock if you have two dual sets or a pair of unmatched sticks the mem runs as fast as the slowest stick unless overclocked to match the fastest, could be wrong on that last count though.
Hope that helps :)
Anyone else?
The Mushkin HP stuff should run at latencies of 2-3-2 at stock speeds, not 3-4-4. So the memory is, as everyone else says, running at the speed of the slowest sticks, in this case the OCZ.
