Calling all MK1 Focus guru's.
A friend of mine has a 54 plate 1.6 Ford Focus. For quite a while now he's had a problem with it in that if he turns the air conditioning on, it lowers the RPM a lot, sometimes to the point of stall. I offered to have a look at it to see if there was anything obviously wrong. I've cleaned the ICV, inspected the boot from the airbox to throttle body for splits and cleaned the throttle body and it has done nothing to help the problem.
The car drives and idles perfectly when the air conditioning is off, but as soon as you push the button to turn it on, it lowers the RPM, then the clutch disengages and the revs return to normal, then it tries to engage the A/C compressor again, then it lowers to the revs to near stall, so it quickly disengages the compressor again and so on and so on. It's almost as though the compressor is putting such a load on the engine, that it can't handle it.
I would have started pointing the finger at the air con compressor, but it is fine for the first 2 minutes on a cold engine and only starts playing up when the cold start procedure is over and the revs settle at ~800rpm. The other thing that i noticed is that the fan (single fan car) doesn't turn on when the A/C turns on, nor does it start even when I got the engine coolant to 119c!
So, like I said, can any Focus guru's lend a hand?
