The clutch on my trusty MK3 golf is starting to slip so I assume it will be on its way out fairly soon, it's done very nearly 220,000 miles and I don't know when the clutch was last changed!
I've got a few questions, having never changed a clutch before...
Which bits need replacing? The haynes manual lists the release mechanism, the pressure plate, and the driven plate...
How diffcult a job is it to do given I've never done a clutch before? Done in a morning? I've got enough tools but not a lift or anything to take the gearbox out if that is needed?
