MK3 Mondeo door removal
18 Oct 2002
does anyone here know how to remove a door trim panel on the front passenger door of a mondeo?
Dad has managed to find all the screws on the outside of the door, but something is holding it on in the middle of the door. He cant see anything obvious, so any idea where the other screw is hiding?
Where I have my grab handle on the door in my Focus I have a plastic cover. If you feel along the bottom of the handle you may feel a small hole, if so it could be the same as mine. Which i can to use a flat headed screwdriver up the gap to pop the plastic bit out which revealed 2 large screws.
Also do you happen to know whether the wiper stalk is a 6 speed intermitent (sp?) one? If so what spec Mondeo is it?
It's ok mate, just pull it off, if it breaks then just us some superglue to put it back - good as new.... literally :p
