My front tyres look a little low on tyre pressure, so I thought I'd check the pressures on all of the tyres and increase them if necessary.
In my manual, it says the following:
Front: 2.1 / 2.4 (up to half payload / up to full payload)
Rear: 2.1 / 3.2 (up to half payload / up to full payload)
I'm a little confused, which pressure do I need to fill them up to, or are they the minimum and maximum pressures?
Also, what are they in psi?
Tyre size is 175/80R14 if that helps.
