While listening to the radio the other day I thought the balance must have been shifted fully to the left.
After some tinkering it appears that there's less sound coming out of the driver's tweeter than the passenger side.
I whipped off the door cards and swapped the tweeters over but both appear to be working fine.
It seems as if the cross-over is borked but as I understand it, the tweeters are driven from the mid range speaker.
Is this a common fault? Could it be caused by the headunit at all? (seems unlikely).
I would normally use this as an opportunity to upgrade but I don't have the funds at the moment.
I'm hoping there's a simple fix, cheers for any advise.
