MKV playback issues
20 Aug 2004
Bournemouth
Ok heres a confusing problem for you guys!
Got hold of a bunch of 70mb MKV family videos from a legitimate legal source online. Problem is they're 21 mins long and on half of them the audio stops at 19:00 exactly. Most are fine but several do this and its annoying cause I'm missing the endings.
I've tried playing them in media player classic first, then winamp, wmp, vlc, xbmc... Cant figure it out!
Just sounds to me the video file is corrupt - either the actual file is corrupt or it didn't download right
Hmmm I guess they could be corrupt downloads. if the connewction hiccuped or something. Doh. I'll try reaquiring one as a test sample.
Hey its not MY family! And I got the file again and same problem :( Guess I'm going to have to miss out on the endings of a lot of these then.
The resolution of them must be awful :/ An average 20minute MKV of mine in standard def is 350MB!
720p is often around 600MB
What codec does the video and audio use? MKV's can contain pretty much anything. Can other "members of your family" view the problematic files right to the end or is it just you?
This is what it looks like on the inside:
and yes the quality isnt amazing but its fine to view on 2nd screen while I'm busy on the main. Its still as good as some 350mb avis I've seen. And not sure which 720p you get but mine are all 1.09gb!
That's interesting. If reasonable enough to View I may compress more. Hmm you may be right on reflection, certains shows do some to be around 1gb
Torrents are usually half that and the quality is fine, remember that a home movie doesn't require any more than 64Kb/s audio to sound fine and h.264 allows much better compression than torrents use. If the video is low motion then using a constant quality setting could achieve reasonable results for a standard vga video.
