Mkv to Avi Help
19 Oct 2002
Bath
Hi guys am trying to convert a 4gb Mkv to a smaller (1.5gb) avi so i can play it on my media pc with no problems.
I am using super to convert the file but the video is going super fast and the audio is normal speed! any idea whats gone wrong?
What settings would you recommend for output in super?
Any and all help appreciated. Thanks in advance :)
Bigboy
I wouldnt bother, the quality loss would make it pointless. If its an x264 mkv, check out CoreAVC. Even old hardware should be able to run it with the proper codecs.
