mkv to DVD
18 Oct 2002
Kent
Apologies if this is in the wrong forum, wasn't sure if the optical drive section would be the right place.
I want to burn 720p mkv files to DVD so my mum can just bung them straight in her DVD player. I did a google search and there seems to be a lot of information and software available so i want to check with you lot to see if there is some kind of consensus as to which piece of software is best.
Thank you kindly.
Thanks guys. I've downloaded the trial version but i cant find any info on whats missing from the paid version. Any ideas?
Ah right, thanks.
One last thing, is there anything i can/should do to make sure it makes full use of my CPU for encoding?
Convertx2dvd but make sure you select the option for 2 channel audio otherwise there can be issues playing a 5.1 film back on a tv in my experience.
