ML 110 G6 with 2x WD Red 4TB ?
29 May 2017
Hello,
I need to upgrade storage of HP ML 110 G6 with 2x WD Red 4TB.
As searching through forums I found information that only 2TB SATA are supported for using with integrated B110i .
As I must have RAID in this setup, here is the issue.
I could get Lycom PE-115H and I just wanted to know if it is supported with ML 110 G6 , off-course considering that WD Reds 2x4TB would be usable?
TY
Thank you for quick response Armageus, I also was leaning towards P212, but friend offered me for testing that taiwan Lycom, so I just wanted to check if anyone used it in similar situation. 2x4TB will be 2nd logical drive in RAID 0
I suppose with P212 I could also get a chance to keep 1st logical drive transfer from B110i (2x500GB Win2008) without breaking RAID and needing to do BareMetalRestore on new controller.
There's a difference between supported and works - it won't be supported but will (probably...) work if the device has the right interface and driver.
Yep. Bought the ML110 G6 off a mate a few years back with a Pentium G9650 installed, and used it as a ESXi lab host... upgraded the processor to a Xeon X3450, stuck in a couple of sticks of matching memory, those hard drives, and it's running as a NAS and Plex server quite nicely.
This is the first information I found that 4TB can be seen through B110i in RAID mode, everywhere else there were issues like this one:
febxhu
https://prnt.sc/febxhu
febxhu
Undergroove if catch up time on next reboot, please share BIOS version, thanks.
Will do... hopefully won't have egg on my face, but happy to admit if it's not quite working how I thought it was (damn computers)!
Update on upgrading storage :
-I kept integrated B110i for OS drives
-Installed on Marvell 19xx RaidCard with 2x4TB in R1 mode,
everything is working nicely and prob will keep configuration.
Thanks to community for support, cheers ;)
