I'm looking for a new CPU cooler and 2x 80mm quiet fans to fit inside the ML03B case which is a HTPC, current specs are,
CPU: AMD Phenom II X2 545 3.0GHz
Motherboard: Foxconn A7VMX-K
GPU: Asus ATi Radeon 6450 Fanless
The current CPU cooler (Cooler Master CM12V) is quite loud as I can hear it while watching movies so I'm looking for a new CPU cooler which is quiet and can shift a lot of air around the case. The 2 RAM sticks are low profile so this is an advantage,
The case only has two fans (CPU and PSU) as the GPU is passive cooling so I'm looking for 2x 80mm quiet fans to fit on the side of the case to create more airflow,
The ML03B case is on the bottom shelf but has a bit of room between the top shelf,
