hi
just wondering which one is best to get if you are offered them at the same price??
I know on the ml115 if you want to use raid and a local esxi (3.5) you need the adaptec sata controller (40quid), on the ml110 on board sata is ok?
I just want to run esxi and play around with VM Machines, explore as much as i can at home to further my experience/knowledge.
but that issue put aside if both servers are going for the same price which ones would you recommend?
any advise much appreciated.
thanks
thanks
