- 4 Nov 2004
- Norn' Iron'
I've had this case for years now and always ran it as per this:
LHS front 3 fans blowing in over components and CPU heatsink
Top 2 fans (above CPU heatisnk) blowing out
LHS rear fan (behind CPU heatsink) blowing out
RHS front fan blowing in towards PSU
RHS rear 2 fans blowing out behind the 6 HDD's
Im now going to be water cooling so the 3 fans on the LHS front will be pulling air through the 360 rad and I had planned on keeping the other fans in the same orientation. What are your're thoughts on this. Should I aim for negative or positive case pressure?
