MMO rig
25 Dec 2012
Hi Guys,
Bought a pc from O/C this year and am really happy with the service so now I am back looking for a computer for my daughter (mainly so I can get her off my PC).
It will mainly be for playing World of Warcraft and similiar MMO's.
I will need an operating system for it but peripherals are sorted.
The buget I have to play with is around £500 but could push a little higher is needed and I don't plan to build it myself.
Thanks in advance for any help.
I agree, my budget is a little low. I will edit the main post to a more reasonable amount.
I just don't have the time to self build and would prefer a pre built system.
I have looked at that system and have to admit it did seem to tick all the right boxes.
The only points that worry me are:
Windows 8, and if the on board GPU is up to the task.
I know that you can add another gfx for a hybrid set up, however from what I see that only shines in a 1080 resolution and at other resolutions doesn't offer much more poke.
Anyway lets see what other ideas are put forward now I have a larger budget ;)
