MMOPG Gaming Disconection problem
31 May 2005
Hi I hope someone can help me with this bizzare problem as I have run out of ideas.
Im an online gamer and love playing World of warcraft with my girlfriend
I have a D-Link router DSL - G624M and we both have our own accounts of the game, we can surf all day and my connection is solid which also connects at 8.1mbs.
I recently moved house and switched to a new ISP and since have been plagued by some horrible in-game disconnects.
the bizzare problem is that it will only affect 1 of the 2 pc's never both at the same time what tends to happen is it will begin to lag, then the game freeze and will either catch up after 30 seconds or boot one of us out, either way it is unplayable but the internet connection still remains.
I have updated on both PC's the graphics drivers, defraged, virus checked, spyware checked etc and there are no problems that I can see.
I havent updated the Sound Card driver but will if it makes a difference?
I have followed blizzards (the game makers) instructions on their website but theres nothing I can do to stop this random disconection problem.
I've looked at my network configuration and so far I have on both pcs
Checksome Offload - enable
Flow control - enable
IEEE802 Support Disable
Jumbo Fram Payload Size - 1500
Low Power State Link speed - Enable
Nework Address - not present
Optimize for - Throuput
Segmentation Offload - enable
Speed Duplex settings - Force 100 Full Duplex
VLAN id - 1
VLAN Support - disable
WakeonLan From Power off -Enable
The only settings I have changed here are recomandations from Blizzard in that I should Force 100 Full Duplex and Optimize for throuput.
The other settings I havent changed and to be honest I don't know what they do anyway, Im not sure if the problem lies here.
I'm trying to update my drivers for the network card to rule out that possibility but my pc is a Lan Party Ultra D and the other is an Asus SLI Delexue
board.
Im using the nforce nvidia networking controller (not the Marvel Yukon Ethernet Controller) on both pcs and looking at the driver its dated 4.6.6.0 from the 24/11/2004 (it is an onboard motherboard network port, part of the chipset). Perhaps that really should be updated?
I've been to Nvidia's site and thought I was downloading an updated driver, installed it but it didn't change anything so I assume it wasn't that one.
So I'm really not sure what to do or where to go next, totally bafflled I know this problem is just isolated to me as when I do play online in Raids etc there are 40 people in the Raid group, all of who don't get disconnected at all.
whats stranger is it can occur slightly then go away then come back when you least expect it.
Thanks in advance for any help
I used to get a problem like that when entering places with loads of people like Ironforge.
Updated my network card drivers and it sorted it.
But I see you've already done that :(
