- 1 Nov 2011
Guys - so i attempted to build my first loop some weeks ago!
I had completely killed my gtx 470!
Now, I ordered a GTX 560 TI and some mosfet blocks too!
So here is my final build! leak testing atm! needing another bottle of coolant! it's already taken 2 litres!
Here's a video to the build at leak testing stage!
So, the build is:
Rampage II Extreme
i7 920 @ 4.2GHz 1.3V
12GB Dominator RAM @ 1600MHz 1.65V
EVGA GTX 560 TI @ 900MHz
x5 OCZ Vertex 2 SSD's
Hiper 880W PSU
All EK blocks - (CPU, RAM, Motherboard, x2 MOSFET, GFX Card)
Tubing is Masterclear 1/2"
Fittings are Generic Black Nickel
XSPC Laing D5 Pump/Bay Res
Radiator is MO-RA 3 9x140
Running all completely passive!
temps are about 27 idle & 65 max load
So, the build is:
Rampage II Extreme
Hiper 880W PSU
then build a vented but hopefully as sound proof as possible cover for the fireplace and have the pump/rad/fans all essentially removed from the room. It will also, with a nice seal push all the hot air from comp straight up the chimney rather than into the room. So many things you can do if you cool outside the case.
