MO-RA 3 Pro 9x140
1 Nov 2011
sooo...i'm settled on one of these rads....
question: would i need a particular pump with one of these rads?
(i've only got the EK Supreme HF blocks for cpu, gpu and motherboard...
are there any other "particular" parts i would need specifically to use in conjunction with this rad?
You need a pump in general to circulate water throughout your loop. Get a mcp655 or something along those lines and it will be fine.
If memory serves me well the mora has very low restriction so pumping pressure should not be an issue. As for running passive, if any single rad could do it the Mo Ra is certainly the top contender.
