Ok, now I have a socket 754 mobile sempron gutted from a broken laptop. Is it worth looking into the overclocking possibilities of this? I'm aware of the following:
-The range of socket 754 semprons are v overclockable
-The mobile sempron's heatpad is much smaller than the desktop equivalent
-The mobile chip is a 3000+ (1.8GHz)
-has stock voltage 1.2V
-is operable to 95degrees C
-has Cache 128kb
This is all taken from the OPN number which if you want to check is SMS3000BOX2LB (which i'm informed has been changed to SMS3000BQX2LE).
I was thinking with such low voltage and high temperature tolerance surely this chip will love to be overclocked.
What do you think?
Dannnn
-has Cache 128kb
What do you think?
Dannnn
