Mobo and CPU upgrade
1 Oct 2013
Evening fine helpers!
I am looking to upgrade my motherboard and CPU (with a fine offer from OC) - i previously used the forums a couple of years back to get a shopping list within my budget.
I am looking for guidance and which CPU and mobo to purchase - how can i go about linking my system specs onto this thread to get advice from you guys about upgrading the above?
thanks in advance
current hardware
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard
Cooler Master CM-690 III - USB 3.0 ATX Case -
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366)
Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive (SH103S3/120G)
Gigabyte Radeon R9 280X Rev2.0 WindForce 3X OC 3072MB GDDR5 PCI-Express Graphics Card
my mobo is poop though ^^ doesnt even support dx11 along with i wouldnt even know where to start with overclocking ;p
thanks for the guide - followed to the T i ran some basic stress test software and it came out at 3.3 still? how can i check definitely that it has worked ?
again thanks for the guide!
Yeah you have no reason to upgrade at all. Just upgrade your GPU instead.
My brother has a 2500K running at 4.6ghz stable, they are a very beastly still.
Agree. I have a 2500k @ 4.5GHz, and I honestly don't know when I'll replace it.
I was thinking I might migrate to Skylake when it comes out, but not sure it would be particularly worthwhile. It's only a couple of months away from taking the record for my longest-serving CPU from my old Q6600. Been a cracking piece of silicon.
yet again the forums deliver - thanks for the advice. Overclock is stable and working like a dream @ 4.4ghz
as for the GPU i have the 280x which i havent looked at overclocking yet ... if only there was a guide *look to the forums i go*
thanks people! :)
thanks people! :)
Go into the performance tab in AMD control center, there's an option to enable gpu overdrive , and will give you the option to alter your clock settings or you can download MSI afterburner which i prefer for custom fan profile and more options for stuff in general on my amd machines.
have a 280x in my media pc , should be able to get a good 10/15% overlock on it
