Hi basically putting a rough spec together for my build in march. Of course new products will have came out by then.
Heres what I've come up with.
Which motherboard should i get? Ill be doing some overclocking and i don't think ill be going SLI but it'd be nice to have the option.
And which PSU should i get? I hear the Corsair range is good. Would the smaller 450w model do or should i get the 520w model for extra leg room?
Also budget is about £80 for both Max. So £140 Max.
Also ive decided to pick 2 Hard drives. One for windows and installs and the other for Files, Music, pictures etc. Is it better if i just put one large drive in and put all my pictures music etc on a External HD or keep it the same?
Thanks in advanced
Thanks in advanced
