mobo connections
16 Dec 2010
do all these connections look ok there seems to be empty pin conection and not sure if aye should be attaching the digi audio somwere as hdaudio is already attached
[/URL] Uploaded with ImageShack.us[/IMG]
You have one empty USB which could supply another two ports with a suitable bracket. I cannot see what the other ones are, not all motherboards or cases have all the connections. You need a power switch connected, all others are optional, HDD led, power led, reset switch, speaker etc.
Digi audio, is that from the optical drive? usually the sata or IDE cable deals with digital audio, analog audio from a DVD drive used to require a seperate lead.
andy
andy
theres 4 usb on front of case and 4 on back only had 2 conecters tht said usb there wasnt another one , put up some clearer pics aint sure were that didi audio is going the manual recomended a use the hd audio so a put that in the digi one is attatched to same cable
