Mobo, CPU and RAM for £400 tops
6 Nov 2005
Newcastle,UK
As the title says please guys, I need those 3 things, within a £400 budget.
Preferably an E6600 if that is possible, if not then feel free bung up some alternatives :)
Cheers
Bry.
p5ne sli
e6300 oem
scythe ninja
geil pc6400 THIS WEEK ONLY
total is 348 inc VAT
getting A 6600 will put you over budget, with this board you will be able to overclock this easy to 3ghz and have one of the best coolers to go with it.
6600 main advantage is it has 4mb of cache, but in realworld differences are very little. It only makes a big difference if you are Video editing.
mattpj's suggestions sound good to me, you might find that a 4300 is marginally easier to overclock due to the higher multiplier. If you don't want to overclock then you could go with the below specification and it is just over budget. :)
Asus P5N-E SLi nForce 650 (Socket 775) PCI-Express DDR2 Motherboard £69.99
(£82.24) £69.99
(£82.24)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £173.99
(£204.44) £173.99
(£204.44)
GeIL 2GB (2x1GB) PC6400C5 800MHz Value DDR2 Dual Channel Kit (GX22GB6400DC) £94.99
(£111.61) £94.99
(£111.61)
Sub Total : £338.97
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £8.25
Vat : £60.76
Total : £407.98
Cheers guys :)
I have been looking at the E4300's, I will mull it over and see what happens, got £400 burning a hole in my pocket and I want to spend it :p
Bry.
I have 4300, they are easy to overclock. Some argue one is better than the other. The fact is they are both good chips. I flipped a coin and went with the 4300.
