The time has come to retire my long serving Socket A rig, it just can't keep up with today's demands which, in my case are playing HD content, encoding in a reasonable amount of time and needing more than 2 SATA ports.
Here's a pic for those of you into antiques hehe.
So requirements:
A Mobo with onboard graphics/sound, HD is CPU heavy as I understand it so an onboard GC should be enough to playback HD?
A CPU, something that's capable of playing HD and can encode 30 mins of video in less than 75 mins.
A heat sink.
RAM, 2-3GB should be enough. (Got 2 atm and it's plenty)
I'll be getting a monitor and TV card, it'll all be going into a Cooler Master Praetorian (pictured) and I'm using XP 32-Bit atm but can upgrade to W7 if need be.
Not done a build since this socket a so not sure what I should be looking for, I want to keep the budget as low as possible but not compromise performance too much. Oh and I'd like to keep the noise down.
Willing to OC for the first time in my life as long as it's stable and doesn't add too much heat/noise.
Your help and comments very much needed and appreciated.
Thanks in advance
john
So requirements:
A heat sink.
Thanks in advance
john
