mobo/cpu/memory spec check
8 May 2007
mobo Gigabyte GA_P35C
http://www.overclockers.co.uk/showproduct.php?prodid=MB-086-GI
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
http://www.overclockers.co.uk/showproduct.php?prodid=MY-088-CR
Intel Core 2 Quad Pro Q6600
http://www.overclockers.co.uk/showproduct.php?prodid=CP-143-IN
£331.31 inc VAT
after abit of thinking ive decided to go for the quad cpu
anything that you would chance? is the hs/fan that comes with the q6600 decent enough to get a decent overclock out of it? or should i get a 3rd party one if so which?
thanx for the help :)
Careful with case clearance and those heatsinks though. That gigabyte boards good, but the location of the CPU does make clearance a little tighter.
