- 20 Sep 2012
I'm currently running:
Vista 64
Asus m4n2-sli am2
Athlon x2 64 5200
4gb ddr2
GTX 460 750mb
WD 750gb
Hitachi 250gb
OCZ 500w
Phillips 22"
EDIT: Fan - Zalman 13cm 2-bearing with a giant copper cage, cools well but sounds like a blender, on 50% it matches the GTX fan. I would consider upgrading it if I'd need a new one for a new CPU, if stock ones aren't sufficient these days.
I've never really had much issues with it as I'm a few years behind in playing through games (stupid steam sales) so I'm not needing to max out skyrim, but I'm catching up to things like Borderlands and Saints Row 3 which don't run amazingly and freeze/lag. General running for browsing and using office is also starting to become a real pain, freezing for a few seconds about every 10 minutes with CPU spikes. (99% sure virus free)
The GPU, HD and monitor are all only around a year old, so I was only really looking at replacing the processor, but even getting the best I can for my current motherboard is a bit pointless.
So, I am after recommendations for a suitable motherboard and processor combo to match my GPU, plus 4gb vs 8gb ram. I will graduate in a year and hopefully be earning a bit more money and maybe in 18 months sell my current rig and do a better build.
Budget - under £200 seems reasonable considering I'm not after a top end CPU, although I'm not sure if I really need a very good motherboard either, for example if I need to spend £30 or £80.
Thanks for looking.
Vista 64
Asus m4n2-sli am2
Athlon x2 64 5200
4gb ddr2
GTX 460 750mb
WD 750gb
Hitachi 250gb
OCZ 500w
Phillips 22"
Thanks for looking.
