mobo dead?
19 May 2012
Belfast
hello everyone,
I did a case swap and now mypc is dead all i get is the power led and turbo key 2 led flashing on an asus m4a88td-v evo usb3.I have dun everything i know of and followed suggestions from everywhere else.can any one help me shed some light on this.
cheers Type42
Hello and welcome to the forum :)
I assume you have tried the following:
Removed all ram bar one memory module.
Reset the CMOS
Rechecked all connections are tight and the 8 or 4 pin for cpu is connected.
Check the power switch on the new case is operational.
Retry external to the case to rule out possible shorting issue.
Reset the CMOS
what would i place the mobo on when running outside the case?and i have tried your recommendations.
cheers Type42
Have you tried running it out of the new case as suggested? you can just put it on a cardboard box or a table or something - anywhere that isn't conductive. This will tell you if it's a physical problem with the installation into the case, or something hardware related.
Just after doing that now mate,still no joy just the mobo and turbokey 2 led's flashing.
