MoBo for a beginner overclocker
16 Jun 2003
Romney Marsh, Kent
I've got permission from my wife to build a new PC, I've committed myself now by buying my case (Cooler Master CM-690 II Advanced Dominator and am looking at what board to get.
I plan to put a Core i5-2500K 3.30GHz (Sandybridge) in whatever I get.
I've read up on Z68 and don't think I'll make good use of the facilities it offers.
By all accounts, the MSI P67A-GD65 Intel P67 (socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION is a good board especially as it currently come with a free cooler.
BUT... reading a review it stated:
The P67A-GD65 is good but falls short of greatness. Overclocking it is a chore, although MSI tells us it’s addressing this. The price works against it too, and while voltage readout points and on-board power switches are desirable, you won’t use them every day. We’d recommend buying the Asus P8P67 over the GD65.
The "overclocking is a chore" bit causes me a little concern though.
Is this a good board for a newbie overclocker or is there a better alternative I should be looking at.
The free fan is nice but I have had a little though about installing a Corsair Hydro H60 High Performance Liquid CPU Cooler don't won't my decision to be totally upon the free fan - however there is every chance I'll start with the fan and upgrade the colling at a later date.
I also won't be using a SSD but would like to in future. Whatever board I get will probably last me few a good few years.
So, can I do better than a GD85 without extending the budget (a few pounds may be allowed for a much better option).
i think you should go for the MSI P67A GD65 it seems to have got some decent reviews. I dont see how its a chore as it comes with the genie button. which will set it to 4.2 itself although it may give it a little extra volatge
I'd say go for the P67A-GD65. A more expensive board doesn't mean it's better than the cheaper variants of the board. In my opinion, the most expensive variants of the boards seems to be worse in OCing compared to the lower variants. Some boards are more expensive than others because they add bling to the board. (i.e. 4 gigabit LAN, more USB 3.0 sockets and such) I also think that getting the most expensive variants of the board doesn't suit beginner OCers as it has got more advanced options that makes it overwhelming for the user.
The P67A variants of MSI are really good clockers. If you want to overclock, I'd get the GD65 whilst it's discounted and even has a free cooler. Also, the BIOS layout between the GD85 and GD65 is the same. Plus, you'd find plenty of overclocking info with the board as it's more popular against enthusiats.
P.S. Get yourself another extra fan for push/pull config on your cooler if you decide to go for the GD65.
I overclocked my 2600K to 4.8GHz in about 5 minutes on the MSI P67A-GD65.
At the moment the price is £124.99 including a free £19.99 cooler. In effect the motherboard is £105.
Absolute bargain.
Looks like my decision is pretty much made now but I'm still open to advice.
Also, watch out for a similar graphics card thread coming soon (based upon a 6850 but open to alternatives)
I would take what some review sites say with a pinch of salt. They are often very biased. The MSI board is not one that I own personally. But my partner has used one to great success in the MSI contest on this forum. And he rated it highly when he used it.
They are all the same really - motherboards that is. And they all clock very easy too. SandyBridge has taken the difficult out of overclocking. You will be very happy with the GD65.
+1, the oc genie button makes oc'ing a breeze, and although msi recommend against it, while the oc genie is on, you can lower the voltages slightly.
got this board 3 or 4 days before this deal started for £140 and no free cooler, and cant be bothered returning it under DSR to re order it lol.
£124.99 is an absolute steal for the gd65 and cooler, got no complaints here...
Thanks for all the advice, I have now placed my order for the GD65.
Just playing the waiting game for all the parts to turn up :D
