- 24 Dec 2010
- Anglesey
Hi I recently bought a msi 970a g43 mobo to go with my 8350 as people on other forums said it would be fine, but as I researched further there was quite a few people having problems with it working with the 8350. So had to send it back.
This is my first build so I dont want to encounter any problems after I build it all because I wouldnt know how to resolve the issue.
This will be my build.
Amd 8350
R9 270x 4gb
8gb ram 1600 mhz
Ive only put down them 3 components because im not really sure what you need to know when speccing a motherboard.
I will possibly be overclocking, although ive had no experience doing so, so it depends how simple and safe it is.
Budget for mobo is £70-80.
Thanks in advance for any input.
Budget for my whole build is £650 with o/s. Feel free to spec me a whole build for this amount if you think I can get a better deal with this amount.
Amd 8350
R9 270x 4gb
8gb ram 1600 mhz
