Mobo for overclocking an i7 3770
16 Dec 2012
Bath
What would be the best motherboard to overclock an i7-3770 on. I would prefer to be able to clock it to 4.4 - 4.6 so i was wondering what motherboard would be the best / cheapest / most reliable for what I want. I will be buying an appropriate heat sink to go with it so the motherboard is my only worry currently.
Hi,
Heres two boards to consider (ATX form factor is ok right?)
YOUR BASKET
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £112.99
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £89.99
Total : £214.38 (includes shipping : £9.50).
Both have a 3 year warranty and Gigabyte have a UK based RMA centre.
The more expensive board supports Crossfire and SLI at 8X/8X
The cheaper board supports Crossfire only and thats at 16X/4X, if a single GFX card is all that interests you then it will be fine to use.
A more detailed side by side comparison can be found here.
