MOBO has no WIFI antenna in the box, help.
22 Oct 2008
Lisburn
I bought the above as a B grade, but it didn't come with ANY WiFi antenna in the box. Now I know b grade might have things missing but to have no wifi option really sucks. What should I be looking for in terms of buying replacements? Can I buy any replacement or does it need to be specific? If specific, what should I get?
Just ones that mention WiFi and Bluetooth. I actually had to buy a replacement for a family member, they broke theirs when they were moving. It was "Eightwood External Wifi Antenna" on the rainforest, had a magnetic base so was able to position it better.
Did you order one? if not don’t. I can send you one :) i recently got a new motherboard myself and it came with a wi-fi antenna and the connection system is identical on the back of the board. I can’t imagine there will be any sort of software lock stopping it from working on an asrok board.
Legitimately a great thing to offer.
10/10 for being a bro.
Haven't ordered one no. If you could send it, that would be amazing. I'll send you a freebie from our store as a thank you. If it's still ok, send me a message as we'll make arrangements. Thank you so much
I once ordered a B Grade Hazro monitor years ago, it didn't even come with the stand :p Alas it obviously went back...
Ever since then i've had no issues but I would put an antennae down as an accessory and not a necessity as it'll still work without it, just not as good obviously, awesome to get some help from another member here too :D
no worries pal, i can have it boxed up this evening and posted tomorrow morning for you will message you now.
I screwed on an ancient linksys antenna from an old 54g router to a modern adapter and it seemed to work fine.
