My query is in 2 parts. Firstly I attempted a Bios flash on my MSI P67 last night and you can probably guess where I'm going with this.
It seemed to flash alright then it restarted and has ever since been cycling through startup. It will power on for literally a second then off, repeating this until I remove the power.
I have tried a CMOS clear, changed the jumpers around and removed the battery overnight but it does not appear to have done any good.
Firstly is there any hope for my board?
Secondly, if the answer to Q1 is no, are there any boards around the £80 mark that anyone could recommend? Should I just go with another P67 or move up to Z77?
Any help would be very much appreciated and the sooner the better. If I need a new board I will buy tonight.
Thanks in advance
Thanks in advance
