Mobo help?
Permabanned
25 May 2004
Bristol England
Hi, i have a K8n Neo platinum for socket 754, iv had it 2 or 3 years now. Iv reformatted my PC and even though i have the disk that came with the mobo, its not finding the drivers on it when i search for these 3 things, which means in part, that my computer wont connect to a LAN via the cable bit, i have to use my wireless card. : /
Can anyone tell me where i can get the drivers from for these things, or offer any other advice?
the question marks are on
Multimedia audio controller (im guessing thats my onboard sound)
Other PCi bridge device (got no idea what that is and everything seems to be working fine)
SM bus controller (the big prob i think)
photo bucket is being silly, i apologise for size of pic
Stelly said:
I think its your onboard soundage
The guy on the phone to telewest said it was the reason i couldnt connect to the internet via my lan port and that i needed the drivers, however the drivers arnt on the disk with my mobo came with, any idea's?
yes ...............what you want to do is go to the mb makers website in your case msi and goto the download section and you should be able to search for your board and download all the latest downloads for your board i.e. sound drivers ,latest bios ,manual ....ect ect!
Right, iv found out where to DL the drivers and what not. But once i have the file there no .exe to do anything.
In the XP folder this is all there is? Iv tried running the driver update installer but that doesnt find any of the files as the update. :confused:
killer_uk said:
Right click the setup information one (with the cog) and select install. Should do it.
Ah, didnt realise you could do that, iv done it now, nothing happens :confused: Its like it just refreshes my folder.
