Finally getting close to having put my first build together. Confused about a few things so advice would be great!
(A) The mobo has an ATX 24pin power input and an ATX 12V 2x4 power input. Do I need to plug the relevant cables from the PSU into BOTH? (i.e are they the same thing or not - and in that case what does the 12V do?)
(B) There are several 'sys fan' (1 / 2 / Pwr fan) inputs on the mobo. What should plug into these?
(C) Is it OK for any cables to touch the case sides?
Thanks! This is more tiring than I thought!
