Mobo issue?
26 Oct 2014
Uk
Hi all,
Im having a problem with my Asus P5WD2 Premium mobo, i wanna use it for a server build. all seem to work right, like the CPU fan and the VGA card.
When i turn the pc on, all the fan lights turn up but i cant see anything on the monitor. I've taken the VGA card off ( a ATI 850x 256mb) the card works as its on another mobo right now.
The CPU works as well but for some reason the mobo doesnt work with all this.
I remember that this mobo worked in the past but i packed it away some time back as i upgraded my mobo.
Can someone help resolve this for me.
Thanks.
Has the CPU been used on the board before? If it hasnt it may need a bios update to get the board to pick it up. Also like above do the fans turn at all and if you remove the ram do you get any beep codes from the board?
