Mobo issue
17 Jul 2008
A friends PC, his mate put it together,
I
tried different ram,
tried a different video card
tried a different PSU
tried to reset the BIOS
took off the heat sync
picture is a bit bigger than i expected...
edit, should added for extra lol's
the RAM was in the wrong slots, the wrong way round, and the video card Gforce 980 was in the PCIE x8 slot (or what ever you call the full length slot with only half the pins)
1150 CPU on a 2011 board... lol
plenty of room for upgrades, can fit another CPU in there...
also the RAM was in the wrong slots, the wrong way round, and the video card Gforce 980 was in the PCIE x8 slot (or what ever you call the full length slot with only half the pins)
This. It's a setup. Nobody is that pants on head retarded.
i'm wondering if his "mate" did it on purpose out of jealousy, the CPU cooler was also attached to the case fan connector, both HDD's are attached to the highest numbered SATA ports...
i like the fact they did a good job of applying the thermal paste thought (i rubbed it off before taking the picture)... even though the stock cooler they used has the paste already on it...
If that is all genuine, then it has to be deliberate. No way someone would that daft they'd get all those things so badly wrong in one build!
Ram in back to front, how is that even possible??
