Mobo maybe
20 Sep 2015
Hello there ppl.
I've got a serious problem that I can't diagnose.The problem is manifesting it's self as this.My mobo is not showing all my hd's in the bios.When I look in my computer on the desktop it's showing as having no hd's at all,but when I use the side tab to look for it it says there is a 500gb hd as my main hd but none of the others,of which ther is 4 in total.
The 1st time anything happened was when I tried to turn it on,I plugged the plug into the mains and the pc started up by its self then emediatly turned it's self off again.I then tried to turn it on via the power button with no response.When it did come on after a few attempts I got the blue screen of death.It was coming up with the error code 0xc000000e,which was saying something like device unplugged . I've checked all the sata leads and power leads are sitting correctly.I then reinstalled windows,I then restarted it to go into the bios to see if any hd's was showing which it was showing all 3.I exited the bios to boot to Windows and straight away got the bsod.So as it is now I'm lost as to what is causing this.I've also tried clearing the cmos too.
I've been told it was the mobo that is failing,but then I've been told by someone else it's the psu,so that's where I am now.
Can anyone plz help me.
My specs are as follows.
Mobo Gigabyte z97x-ud3h-be
Cpu intel 4790k
Ram 16gb corsair vengeance 2400 ddr3
Corsair h80 cooler
Psu aerocool 850w bronze certified
Gpu gigabyte 960gtx oc 4gb windforce
Os win 10 pro x64
BTW all the components are only just over 2yrs old with no over clocking at all and only used on a weekend for a few hrs at a time.Excuse any spelling mistakes as this was composed on my mobile
Just spoke to Overclocker's support team and they say it sounds like sata controller is failing or failed.Am RMA'ing it.I have to say the customer support is superb.Will definitely be using OC'ers again.To whoever I spoke to was very helpful indeed,even with me rambling lol.
