Mobo power connections? (Help)
11 Apr 2011
I have a MSI GD53 mobo. For the power connector on it (the 8 pin one) a little cover was clipped over one side of the connections. I have removed it but does this mean I only connect one 4 pin connector?
Put the two 4pins together and stick em in.
You can put as many drives on the daisy chained cables as there are connectors.
Should be two connectors from the front panel, possibly on the same lead?
One is a HD audio and the other is AC97, just use the HD audio into the header on the board and leave the AC97 dangling.
I just double check all the connections on the motherboard like the power switch etc and make sure that everything is plugged in and fire up. If something does not light up then can trouble shoot from there ;)
Stoner81.
