MoBo/PSU
19 Jan 2011
Hi guys,
I've been looking at various overclocked bundles + graphic cards and thinking of purchasing http://www.overclockers.co.uk/showproduct.php?prodid=BU-059-OE&groupid=43&catid=339&subcat= and http://www.overclockers.co.uk/showproduct.php?prodid=GX-071-GI&groupid=701&catid=1914&subcat=1830.
The PSu I've bought is http://www.overclockers.co.uk/showproduct.php?prodid=CA-200-CM&groupid=701&catid=123&subcat=1103 but not sure if I was too quick in getting it as I'm unsure of whether it will capable of handling the mobo and graphics card. IS this OK for that or should I look for something else?
Also got the 922 haf case. Anyone know if this mobo has sufficient connectors for the 3 fans? Couldn't see any.
Cheers.
Gfx card should be ok yeah, though the GX series arent the best but it will do, I'm sure the mobo will have enough headers yes, what do you plan to use the PC for? Just making sure youre buying the best suited bundle for your needs
